Re: Shawnee front end loader question
Posted by TheOldHokiehat you have to even hegin to guess how Shawnee on December 31, 2020 at 04:22:39 [URL] [DELETE] :
In Reply to: Shawnee front end loader question posted by Steve on December 30, 2020 at 21:06:34:
A number of different schemes were used by different OEMs. Need to see a picture of what you have to say for sure. The most popular setup was a splined hub bolted to the crankshaft pulley. A splined pump driveshaft fit into that hub and came out the front to power the pump. A flexible coupler of some sort was used to connect that shaft to the input shaft on the pump. Post pictures.
TOH
