In Reply to: Re: Naa Valve? posted by mhb@ufe on December 16, 2020 at 15:17:39:
I see the external acorn nut and that valve. It is on the right side, high on the RH side of the housing. If you now look down past that valve into the bottom of the now drained fluid housing you will see another something else in the very bottom that could be another "safety" valve. Thanks for the response!
