Re: 53 Jubilee hydraulic
Posted by TheOldHokie on December 15, 2020 at 09:47:14 [URL] [DELETE] :
In Reply to: 53 Jubilee hydraulic posted by Chuck on December 15, 2020 at 09:05:01:
Your OEM pump options are limited.
1) You can now purchase a new vane and rotor kit for roughly $400. Depending on the amount of wear on the pump body that may or may not fix your pump.
2) The other option is to You can replace the vane pump with a new piston pump. You will have about a grand in that.
TOH
