In Reply to: Erickson posted by Ros on December 06, 2020 at 13:35:34:
It's your tractor and you can do whatever you want with it, but, I wouldn't remove the PTO shaft entirely. If you have a newer PTO shaft, it is tad longer than the OEM 1-1/8" one and may not screw all the way on the OEM PTO Cap/Cover. See the LINK for a cap that should fit.
PTO CAPS
NOTE: The 9N-726 cap is cast iron; the 2N-726 cap is stamped steel and used thru the NAA. Both have identical Thread Size of 2-5/8"-12 UN 2A.
