In the middle of a restore on a 50 8N and had a few questions about the original setup. What was originally on them from factory? From what I have read, looks like they came with stays and drawbar (11 hole). And the drawbar clevis? Is this correct? The stays on mine appear to be homemade and will be replaced, as well there is what appears to be a homemade drawbar that pins into the clevis, will likely leave this off and not replace it (I have seen several “swinging drawbars” for sale).
Also, did the clevis pin simply slide up into the clevis and is held in place by the small 1/4” pin? The bottom of my clevis has been retrofitted to accept a longer pin and I would like to get it back as close to original without buying a whole new clevis.
Thanks
