Re: Electronic ignition?
Posted by Jack-Iowa on December 03, 2020 at 09:33:54 [URL] [DELETE] :
In Reply to: Re: Electronic ignition? posted by Peter on December 03, 2020 at 08:01:50:
Sounds like you've done it right and know what you are doing. As long as the wiring is in good shape and you know where they run, I see no reason for a re-wire. Assume you have the wire tables. Problem with the solenoid on the starting circuit they likely also defeated the safety. These creatures normally start pretty easily and will run over you! That said, I own a 2N on which the safety has also been defeated.
Jack - Iowa
