Re: solar charger/maintainer
Posted by Tim Daley(MI) on November 24, 2020 at 07:00:09 [URL] [DELETE] :
In Reply to: solar charger/maintainer posted by cage on November 22, 2020 at 18:06:04:
Why buy two 6V units? You can get a combo 6V/12V unit to be versatile. Don't know about anything solar, waste of time/money IMHO but you do need a FLOAT charger, not standard charger/maintainer. DELTRAN Battery Tender Jr.® ™. It is a popular brand, available at Walmart, $30. A battery charger, even a "trickle" charger, left unattended will eventually boil out a battery. Connect the battery Tender to your battery when the tractor is idle for periods over a week. Maintains a full charge for when you need it most. Don’t think just because you put your battery on a charger it is good. The constant draining and recharging I the cause of battery life depleting. You need to also invest in a good brand battery -not teh cheap bargain house brands. Your time, your money, invest wisely.
BATTERY TENDER JR (6V) BY DELTRAN:
