Re: Starting Circuit Question for the Experienced Guys
Posted by mhb@ufe on November 22, 2020 at 11:57:13 [URL] [DELETE] :
In Reply to: Starting Circuit Question for the Experienced Guys posted by Jerry on November 22, 2020 at 10:04:50:
You shouldn't need a bypass wire for that system. When you converted it to 12 volts did you install a 12 volt coil? If you have a 12 volt coil you don't need the resistor. The resistor is only used with a 6 volt coil. Many of the conversion kits come with a 12 volt coil and a resistor which doesn't make sense.
Mark
