Re: Starting issues...any ideas?
Posted by Lynn Patrick on November 22, 2020 at 09:01:59 [URL] [DELETE] :
In Reply to: Starting issues...any ideas? posted by Travis Webb on November 21, 2020 at 20:49:23:
If "The engine will just roll over and over" why are you suspecting the starter system? Sounds to me like that is working right! I would start w/hotter plugs. I have very good luck w/NGK 3112. Next make sure you have a GOOD set of points set correctly & the timing is spot on.
