Re: Test
Posted by Tim Daley(MI) on November 21, 2020 at 07:00:22 [URL] [DELETE] :
In Reply to: Re: Test posted by Del on November 20, 2020 at 17:31:32:
Del - are you copying and pasting from your account or are you trying to type in the url manually? Here is a the easier way to copy and paste your picture link from IMGUR. Follow the procedure I outlined below in previous post. Instead of using the 'DIRECT LINK' function, scroll down to the one "HTML (web site/blogs)" Click "COPY" and you get a dialog box saying ALLOW or NOT and just 'X' it out, you don't need that. URL box becomes highlighted in green - cursor on it to copy then simply paste that into your message. I use the direct link and add the [center] code so my picture gets centered in my post. I also use a WORD program to test run my messages and pictures so I an do a 'PREVIEW' operation before actually posting my message. This way if a picture didn't come out or I made a typo, I can go back to the WORD document and see why it didn't work and fix it. Often I will miss typing in the quotation marks using the SYMBOL function in WORD not using the keyboard stroke -they are different. By using the aforementioned easy method, you don't have to add anything like that -just copy and paste. Right click over my picture, from the drop down menu, scroll all the way down to PROPERTIES and left click. Another drop down menu appears. Under ADDRESS (URL) is the http code for that picture. Highlight, copy, an paste in a message then add quotes. If you want to save that picture to your PC, just right click on it and select Save As then select where you want to save it in. Your text in your picture message must contain the Left & Right Arrows with quotation marks.
