Re: Test
Posted by Tim Daley(MI) on November 20, 2020 at 15:50:33 [URL] [DELETE] :
In Reply to: Test posted by Del Huebner on November 19, 2020 at 21:06:07:
I pulled up the archives and seems you had this issue back in FEB 2019 -same thing. I then found another old post with one of your pictures and I was able to see it and look at the properties. So must be something you are not doing right as your account works fine. Check the html code again and copy the direct link as I expressed below.
Tim
