Re: Battery Cables
Posted by Travis Webb on November 17, 2020 at 21:43:34 [URL] [DELETE] :
In Reply to: Re: Battery Cables posted by Johnin Mich on November 17, 2020 at 19:28:56:
Thank you. Just to clarify, the ground cable that bolts to the block/frame should be woven ground strap, right? And the cable from the battery to the starter solenoid should be the 00 gauge? Is that correct?
