Re: electrical
Posted by steve on November 17, 2020 at 17:03:46 [URL] [DELETE] :
In Reply to: electrical posted by steve on November 06, 2020 at 15:19:48:
After several days of tracing and replacing, I found that the baffle resister wire (this is the ceramic piece) was broken, so replace that (O'Reilly
Auto Parts). Still no luck, so I replaced the solenoid (also from O'Reilly). No luck. Then I had a Georgia Tech engineer look at it. In about a minute, he found a fuse tucked behind the wiring--the light switch did not have a fuse, so I assumed no fuse. Problem solved.
Lesson learned.
Thanks to everyone who offered advice.
Steve
