Re: Ford NAA Jubilee no oil pressure
Posted by Michford on November 14, 2020 at 12:36:39 [URL] [DELETE] :
In Reply to: Ford NAA Jubilee no oil pressure posted by Adrian on November 14, 2020 at 04:19:01:
You won't be able to spin the oil pump fast enough with a drill to see it build pressure. Check the inlet pipe for the oil pump to make sure it is not cracked or loose and pulling air not oil.
