Re: Fuel system - cleaning
Posted by Peter on November 10, 2020 at 19:32:21 [URL] [DELETE] :
In Reply to: Fuel system - cleaning posted by Peter on November 10, 2020 at 12:49:05:
Managed to get the carburetor apart using a bigger hammer and a cold chisel
Inside there was a heavy build up on the float of some yellowish deposit. It was on everything inside
Just now I am working on cleaning all the parts using the Dremel and a range of grinding bits.
With a bit of luck it is restorable. It's a very heavy cast body so assume this is the original body
