In Reply to: Voltage regulator posted by Patricio on November 02, 2020 at 14:30:51:
You asked this a few weeks ago and I thought then we concluded your best solution was to discard the 12 volt generator and voltage regulator and simply switch them out to a 12 volt alternator. You said then you couldn’t get an A Circuit type vr in your country so changed the generator to 12 volt yet still can’t seem to get a voltage regulator that will work. They ALL can’t be bad! I’ve suspected from the start the problem isn’t in your voltage regulator it must be in the other wiring, possibly the 12 volt generator. Do you plan to just keep buying voltage regulators till you maybe get one that’ll work? Good luck.
John Patrick
