Ford Jubilee Throttled Friction Plate
Posted by JR in AR on October 31, 2020 at 23:39:56 [URL] [DELETE] :
Drove the 2N today to haul firewood. It did great as usual!
My question for tonight about the 53 Jubilee I am rebuilding concerns the ball end that is used to connect the throttle linkage to the friction disk. The hole in the friction plate has become worn and allows this little pin to wobble when you adjust the throttle. If you lift up, the pin pulls out of the plate. This is such a small pin/hole, I am afraid welding is out of the question. I tried JB weld (I know... not great), and it doesnít hold. I need a new plate, but havenít found any online, that are new. Do any of you have a fix for this? I havenít figured this one out yet..
