8N Hydraulic Lift
Posted by Del Huebner on October 28, 2020 at 15:28:33 [URL] [DELETE] :
Cannot get my lift adjusted on the 8N. Loosened the 4 bolts on the quadrant but as far as I can move it and the control lever is only half way up the quadrant and the rod is touching the pump base. When the control lever is at the bottom of the quadrant the lift will not go down. Could the problem be in the pump itself? I just had the top cover rebuilt.
