Re: 8n
Posted by Tim Daley(MI) on October 26, 2020 at 04:10:31 [URL] [DELETE] :
In Reply to: 8n posted by Keith on October 25, 2020 at 09:30:52:
The Ford Tractor Oil Drain Plug, p/n 8N-6734, is used on all models from '39 - '64 -click on LINK below. Get the quality cork style, not the lousy rubber style, those will pinch. Be sure to get all the old gasket material cleaned of the plug surface and the pan mounting surface. Oil drain plug, p/n 9N-6730, has the screen assembly attached which the oil pump pickup tube & cover, p/n 9N-6615, fits into to help filter out debris in the oil. Apply light clean, fresh oil onto gasket surface before tightening down. Avoid overtightening.
