Posi-Drive Starter Drive
Posted by Dean on October 11, 2020 at 09:56:28 [URL] [DELETE] :
I'm attempting to remove the nearly new posi-drive starter drive from my failed (junk) Indian made aftermarket starter to install it on my OEM starter which has now been rebuilt.
The new type starter drive does not use the spiral spring which can be collapsed in order to remove the pin holding the drive to the armature, and I find no way to move the washer back toward the starter in order to remove the pin.
Moreover, in attempting to remove the drive, it has become extended and spinning it on a rotary wire wheel has no effect.
So, two questions: What is the pricedure to remove the pin and how does one retract the drive?
Thanks, in advance.
Dean
