Re: Rubber Boots on Tie Rod Ends
Posted by Tim Daley(MI) on October 07, 2020 at 15:33:34 [URL] [DELETE] :
In Reply to: Rubber Boots on Tie Rod Ends posted by JR in AR on October 06, 2020 at 23:23:11:
Seems I recall you had a Jubilee but all Ford tractor drag links were the same set-up from '39-'64 basically -see pix. Grab the end, pull up, smack arm with a heavy brass hammer. Booties are different for each model.
P/N 78-3332, Front Dust Seal, ... '39-'47
P/N 8M-3332, Front Dust Seal ... '48-'57
P/N 9N-3324L,Rear Tie Rod End ... '39-'57 -originals were leather, rubber available
