Re: Rubber Boots on Tie Rod Ends
Posted by John in Mich on October 07, 2020 at 10:22:50 [URL] [DELETE] :
In Reply to: Rubber Boots on Tie Rod Ends posted by JR in AR on October 06, 2020 at 23:23:11:
Helps to know what tractor that you are working on. That said, on Ns, at the stering box arm, loosen the nut and use a pickle fork to separate the link from the arm. On the front axle end, remove the nut and use the pickle fork. HTH
