Re: 9N main bearing studs
Posted by JimN on September 30, 2020 at 09:29:09 [URL] [DELETE] :
In Reply to: Re: 9N main bearing studs posted by TheOldHokie on September 30, 2020 at 08:32:39:
I get what you are saying, and have considered all of that, the machinist isn't concerned about parts shifting during his work. The .0025 is bearing clearance like you would measure or check with plastigage. Why would I want to accurately machine my crank and have it line-honed (new caps) and then install it with the caps not necessarily centered.....
I basically plan to do this the correct way with properly sized studs. That is not up for debate.
My question to this forum was where can I find the correct studs..
Thanks, appreciate the input,
Jim
