Re: 9N main bearing studs
Posted by Tim Daley(MI) on September 29, 2020 at 06:24:52 [URL] [DELETE] :
In Reply to: Re: 9N main bearing studs posted by TheOldHokie on September 29, 2020 at 06:10:37:
The main thing when using aftermarket/longer stud lengths is to not bottom out the center shoulder on the part going into it and that there is enough thread length to secure the hex nut with. Like Dan said, if hex bolts will work, I'd opt to go with those. Bolts would also be cheaper to buy than studs and you wouldn't have to muck around with lengths much.
