1951 8N 12 volt Runing real rough
Posted by Rick P. on September 28, 2020 at 20:28:44 [URL] [DELETE] :
Hello,
Im new here so I'll try to be brief on my issue. Tractor was running fine then lost power and ran rough but kept going to finish the job, Cleaned all of the fuel system, replaced resister after test output at 4v., Runs worse, will idle, wont throttle up, seem overloading on fuel. Coil tested in limits: 10.8 ohms 2nd, 2 ohms prime. replaced plugs: AL 437, .025 gap, She runs like she is missing, points gap .015, seem to be sparking regularly from testing.
Any advice is greatly appreciated.
Thank you in Advance, life just isn't the same without my 8N! :(
