Re: Oil Gusher...Help!
Posted by Bruce(OR) on September 19, 2020 at 22:03:22 [URL] [DELETE] :
In Reply to: Oil Gusher...Help! posted by Jerry on September 19, 2020 at 20:04:36:
Pull the plugs until you find the oil fouled one. Then do a comp check on that hole. If it can't even bump your thumb off the hole while cranking, you might have found your problem cylinder. . .
