Re: 2n oil filter assembly
Posted by Tim Daley(MI) on September 19, 2020 at 07:12:18 [URL] [DELETE] :
In Reply to: 2n oil filter assembly posted by Francois on September 18, 2020 at 18:39:05:
The lid has a spring. Does your lid leak? No? Move on. Yes? The rubber flat gasket under the lid, and/or the 01A-6749 lid bolt seal has failed. The bolt seal is a fiber type material and works great. Twenty years ago when you bought a new FRAM C-3P or equivalent oil filter, you also got in the kit the large rubber flat gasket that goes under the lid and the 01A-6749 bolt lid gasket -see PIX. Nowadays when you buy a new oil filter, even from CNH, you don't get that 01A-6749 bolt seal, and some don't even give you the large rubber flat gasket. Also, the FRAM C-3 (and other brands) filter don't have the little handle on the top if filter to assist easier removal when you change the filter. The good news is the lid seal/washer part is still made and sold at CNH -SEE PIX. Now some fellas may have had better luck than I using steel, copper, nylon, or plastic washers for the seal, but I never did -they always still leaked. About 16 years ago I bought a handful at my local CNH dealer and stocked up. Also good new20 years ago that first seal I bought is still on my 8N oil filter housing so they are reliable. The ESSENTIAL MANUALS and MPC's are important tools, look at the MPC's in our MANUALS forum.
FORD OIL FILTER:
FORD N-SERIES OIL FILTER CANISTER LID WASHER:
