Re: 8N Newbie, need advice
Posted by Bruce(OR) on September 11, 2020 at 12:56:09 [URL] [DELETE] :
In Reply to: Re: 8N Newbie, need advice posted by Cliff on September 07, 2020 at 19:21:26:
And if your running a 12V system it should be running a 40K volt coil. That voltage will jump a .045 gap with no problem. Points just open to discharge the coil. That 40K voltage is not on the primary circuit that the points are. A wider gap, a hotter spark and a cleaner burn.
Champion plugs generally run on the cold side from the catalog. They run good in the old Chrysler's but I have dealt with too many fouled champs in most every other application. IMO.
