Re: Possible valve noise
Posted by Tlawing on September 07, 2020 at 11:03:31 [URL] [DELETE] :
In Reply to: Re: Possible valve noise posted by Bruce(OR) on September 07, 2020 at 07:23:49:
Thanks for your reply. I have used a 4ft dowel rod. I can not tell for sure. At first I thought it was coming from the starter area. I took the starter off - everything seemed fine. Then I thought it was in the valve area. It could be transferring from anywhere. Thank you again for your help.
