Re: Possible valve noise
Posted by Bruce(OR) on September 06, 2020 at 16:58:11 [URL] [DELETE] :
In Reply to: Possible valve noise posted by Tlawing on September 06, 2020 at 12:03:30:
Comp check indicates sticking valves?
Uh, okay.
That comp check, was it hot or cold? Open or closed throttle?
12V or 6V?
Same number of rotations for each cylinder? Rechecked it?
Wet or dry?
Changed how much on the wet test? up, down?
Did you use a jumper battery to keep the cranking spped the same all the time or is your battery good enough not to drop with extended cranking?
