Re: 8N pump base
Posted by Dave on September 06, 2020 at 11:59:58 [URL] [DELETE] :
In Reply to: 8N pump base posted by Dave on September 05, 2020 at 12:08:39:
When I bought the tractor at auction....they had it running and lift work normal(Went up and down fine). Fluid was normal. I had it stored inside for two years. It wasn't until I put a bush hog on it that it would not lift. I torn it down for inspection and that is when I found the crack. I would say I bought it that way.I ordered a new piston and cylinder before finding this. Has anyone had one TIG repaired? If not possible....I guess I am look for a pump.Thanks for info
