8N pump base
Posted by Dave on September 05, 2020 at 12:08:39 [URL] [DELETE] :
I bought an 8N a couple years ago.It starts and runs. The three point hitch goes up and holds. Well I finally had a chance to hook up a bush hog and it wouldn't lift. Read up on everything and double checked. Did all the visual checks. Tore into it and found a crack in the pump base. It is located just above the intake control valve and the relief valve. (Bottom of the PTO shaft bushing.)
Can this be TIG repaired or am I out of luck?
