Re: Ford 850 over charging
Posted by JMOR on August 24, 2020 at 05:45:40 [URL] [DELETE] :
In Reply to: Ford 850 over charging posted by Nick on August 23, 2020 at 21:37:27:
Todays electro-mechanical VRs are notoriously bad out of the box. Could be your problem. If you failed to polarize correctly, that could have welded the vR contacts closed, resulting in full field and max output all the time. Remove VR cover & check for welded/stuck VR contacts. Remove battery cable first to avoid shorting cover to internal parts of VR.
