Re: Ford 9N timing issues
Posted by Jock(OR) on August 16, 2020 at 23:52:13 [URL] [DELETE] :
In Reply to: Ford 9N timing issues posted by Bruce Ehler on August 16, 2020 at 20:48:54:
The mechanic went bankrupt? Why am I not surprised?
With the intake manifold off, check the position of each valve when it should be at top dead center of the compression stroke. Also that all the valves open and close completely. This should give you an idea about what is happening.
