Re: 8N Rear Axle Gaskets, Shims and Seals
Posted by Tim Daley(MI) on August 16, 2020 at 05:15:06 [URL] [DELETE] :
In Reply to: Re: 8N Rear Axle Gaskets, Shims and Seals posted by Charles Hudson on August 15, 2020 at 11:55:45:
Serial Number means very little. Unless you have an early model you plan on restoring to all original, N's are basically the same. The 9N/2N are the same after s/n 12500, and early 8N all used the front mount distributor. 8N added POSITION CONTROL, new generator and Voltage Regulator, new starter motor w/Solenoid, new wheels, new air cleaner, and new steering to name a few. Some N's, when engines were blown, were then replaced with used engines from other models so many 'mutts' exist out there. It is possible to have a 9N/2N with an 8N motor and vice versa. I advise to get the TISCO complete Carb Kit -the best around. If you need help with your, email me, it's open.
