New 8n sheet metal
Posted by James Lester on August 15, 2020 at 05:11:18 [URL] [DELETE] :
I have a 49 8n that I need to replace the entire hood, doglegs and grille. I know the fitment of the cheap grilles is not good. I am curious about the fitment of the doglegs and hood. The left dogleg and hood joint are eat out on mine(common problem). I recently bought a restoration grade radiator for it, the only difference I see on it is that the original radiator has the drain valve at the bottom of the lower hose spigot and the reproduction has it close to the center. This tractor has not run since 2002 and I am slowly acquiring parts to fix it up.
