Re: 8n Key Switch
Posted by Zman on August 10, 2020 at 10:41:49 [URL] [DELETE] :
In Reply to: Re: 8n Key Switch posted by Tim Daley(MI) on August 10, 2020 at 10:01:26:
Tim ,wow ,I really appreciate your help, since I bought the 8n Iíve been soaking up all the info I can find , spend my evenings immersed in it , actually the tractor we had on the farm was either a 9n or 2n because it was a 3speed and had that style rear wheels , but I prefer the upgrades of the 8n , may in the future seek out a 9n or 2n cause this tractor collecting is ADDICTIVE !!! 8n that I have has been in the same family over 50yrs , appears to be pretty complete , so am hopeful that it is wired correctly, but will definitely check it out , thanks for the carb info as it came with a new carb and like I said previous owner thought it was a 43 so should be same carb ? Apparently I have adobe as I was able to down load the MPC . Am presently awaiting a front mount plow out of Illinois for my 860 , not sure if it is a Dearborn piece , but is not homemade , possibly a dirt blade as there are no springs for it to flip , have the hydraulic valve (Single lever , two hydraulic hoses) under the seat of the 860 , seller said it will hook right up , weíll see. Canít thank you enough for sharing your knowledge and time with me !
