Re: Gasket R/R
Posted by TheOldHokie on August 08, 2020 at 22:21:47 [URL] [DELETE] :
In Reply to: Gasket R/R posted by 8n13325 on August 08, 2020 at 16:46:28:
That "cover" is the hydraulic pump and the PTO shaft runs right through the middle of it. It ain't coming loose until you remove the shaft and disconnect the hydraulic control valve linkage.
TOH
