Re: 8N losing oil prime
Posted by Greg Davis on August 03, 2020 at 12:29:04 [URL] [DELETE] :
In Reply to: Re: 8N losing oil prime posted by TheOldHokie on July 23, 2020 at 09:17:04:
Update: We took oil pump back out of the tractor and the owner took it to the machine shop that put it together. The machinist opened the oil pump up in front of the owner. Gears were .10 under. The owner went to Just 8ns and picked up a new kit for the oil pump. The gears in the new kit were correct on the micrometer according to the numbers you gave us. The machinist was glad to get the information. He had another with the same issue. Now to install the pump on Saturday morning. I'll try to remember to let you know if this works. It should be the cure. Thanks for all your help!
