Re: Golden Jubillee hydrolic pump
Posted by Ultradog MN on July 30, 2020 at 21:00:15 [URL] [DELETE] :
In Reply to: Re: Golden Jubillee hydrolic pump posted by TheOldHokie on July 30, 2020 at 17:41:17:
Dunno.
I haven't done it.
I mostly just mess with the 3 bangers and all mine have factory gear pumps now. Have read about several conversions on the YT Ford board as the early Hundreds also used a vane pump and Ford did make a manifold to convert those.
I do think your price estimates are quite high.
A used pump plus rebuild parts - if needed - wouldn't cost that much.
I have 3 or 4 similar piston pumps for the Thousands and can't give them away.
You should mention your own gear pump conversion to him. Might be what he needs.
On another note, 4 of those 1/2" JIC Male x 3/4-16 Ford O-Ring Port Male fittings should be here Saturday.
