Re: Sherman 54 B or C backhoe compatible with Ford 850?
Posted by Kirk-NJ on July 30, 2020 at 03:54:42 [URL] [DELETE] :
In Reply to: Re: Sherman 54 B or C backhoe compatible with Ford 850? posted by Paul on July 29, 2020 at 09:18:19:
A late '57 will surely have the standard 1 3/8 pto shaft. There are adapters to step down to 1 1/8 shaft. As long as you are not in a hurry and not doing commercial work I wouldn't worry about it. You would probably have to run it at a higher RPM. If your proofmeter works you will see setting for PTO. You will want to be above the Pulley line running somewhere around 2000. Of course this is with no load on it
