Re: Ford 2N Starter
Posted by Bruce (VA) on July 28, 2020 at 11:47:31 [URL] [DELETE] :
In Reply to: Re: Ford 2N Starter posted by Adam on July 28, 2020 at 10:22:55:
w/o seeing it, I can't say for sure if it is ok.....but, the fact that it went in ok tells me that it will work. if it is not 100% seated on the rear of the shaft, it could be making some contact w/ the ring gear.
hook it up and press the starter button. worse case, you break the bendix.
