Re: Need a refresher/split 860
Posted by Michford on July 27, 2020 at 19:48:48 [URL] [DELETE] :
In Reply to: Re: Need a refresher/split 860 posted by lonestarjeff on July 27, 2020 at 00:36:01:
Any luck with your 860? I cut the heads off of some sacrificial bolts to help align the two halves of mine when putting it back together. Maybe roll the back end away and start fresh rolling the trans and rear back to the engine. When everything lines up, it should go right back together without much trouble.
