Re: Stuck Valve Or Worse
Posted by Jack - Iowa on July 25, 2020 at 07:05:59 [URL] [DELETE] :
In Reply to: Re: Stuck Valve Or Worse posted by Charles Hudson on July 24, 2020 at 13:01:19:
My opinion is, I would find a different consultant! He is certainly a negative person.
As for the front end loader: Do you use it? Does it do what you want? If so, it is not junk but has value to you.
You already know if it will "get out of it's own way"! Does it handle the tasks you put it too?
Yes it has a weak cylinder. But again, Does it do what you want it to do?
I believe there have been a number of postings regarding adding hydraulics to these old girls.
As a youth I drove a '39 Ford from SE Iowa to Seattle, most of the time hitting on 7 cylinders. Over the Rockies in high gear which was a huge disappointment.
Your money, your time, your choice. My 2 cents. Here is Iowa we also know long, cold winters some years.
Good Luck,
Jack - Iowa
