Re: Power Steering Start Up Problem, Ford 850
Posted by Ultradog MN on July 22, 2020 at 05:38:02 [URL] [DELETE] :
In Reply to: Power Steering Start Up Problem, Ford 850 posted by LarryMaine on July 21, 2020 at 13:29:01:
You may have been able to turn it at first because you had only air in the lines.
I'm thinking you may have the lines to the cylinders crossed.
Lift the front axle off the ground and disconnect your steering cylinders on the front end and let them hang from the drag links with a wire. Then start the tractor and see if they move in the same direction as the drag link when you steer it manually. It takes some concentration/thinking to get your head around the cylinder and drag link moving the same way when you turn the wheel. Does me anyway. So just watch one side at a time.
Let us know what you find.
Those tractors steered pretty easily without PS but once you have it working you will cry if you have to go manual :)
