NAA Starting issues
Posted by Dan J on July 19, 2020 at 12:20:50 [URL] [DELETE] :
I have a 54 NAA 6v pos ground. If the resistor goes bad would it cause a tractor to run if pull started, but not start with starter switch? Battery is good, engine cranks just won't start. Points are gapped correctly. Runs great after a pull start.
