Re: Correct 8N Fan Belt?
Posted by Tim Daley(MI) on July 19, 2020 at 03:33:23 [URL] [DELETE] :
In Reply to: Re: Correct 8N Fan Belt? posted by Jim Lovejoy on July 18, 2020 at 23:08:37:
Is it possible you have the wrong generator and pulley on it? The pulley size will affect size. I'd hold off on the auto parts store visit. Part number is 9N-8620-B. When I tighten my 8N generator and belt, I use a crowbar and press against the manifold to the barrel to reach desired tension then tighten down. What are you using for the tension arm?
