9N ?
Posted by Tiger Dobrenic on July 17, 2020 at 16:29:37 [URL] [DELETE] :
I got a tractor suppose to be 9N and trying to rewire it after 3 yrs of rebuild on it but I see that had a cut out on it and a relay regulator as well, I do not see any wiring diagrams with both yet, when I took them off they looked original and I have a star at the front of my serial number and after it but he number is 26426 it all looked original when I rebuilt it , it has radial arms not I beam type, ferguson butterfly type radiator screen with ferguson and ford label in middle, a generator 2 brush with the 2 set screws tapped into it and the spring bolt adjustment. The steering wheel has three metal arms and the hydro fluid stick is in the rear right on cover. Can anyone tell me which tractor and year this is ??? So, I can rewire it correctly and remove either a cut out or regulator relay?
