Re: 621 carb
Posted by JMOR on July 05, 2020 at 17:46:57 [URL] [DELETE] :
In Reply to: Re: 621 carb posted by Doug on July 05, 2020 at 17:02:17:
If a viton tip needle on float, it may be sticking to seat or float may not be free to move, maybe rubbing against side of bowl. Also, if you have flipped sediment bowl for a different line connection, I'm pretty sure the hollow bolt holes and sediment assy holes can have an alignment problem & restrict flow.
