Re: 12v generator
Posted by Tim Daley(MI) on June 30, 2020 at 03:47:26 [URL] [DELETE] :
In Reply to: 12v generator posted by Patricio on June 29, 2020 at 14:02:02:
Another option is to eschew the VR & GEN altogether and opt to go to with an alternator as you already have a 12V battery source. Dennis Carpenter sells parts internationally but shipping is estimated at $60.00 or 60% of the total of the order. If it is over sized parts the shipping is a lot more and the shipping does not include duties or brokerage fees -those are due upon arrival of the parts. I have the correct VR and an OEM, rebuilt 8N-10000B generator but also would cost you 5 times the amount. Use JMOR's WIRING PICTOGRAMS for connecting the side mount 8N distributor setup to 12V. You will need to change all lamps to 12V units too if not already done. 12V sealed beam headlights are Industry Standard #4419.
FORD 8N TRACTOR 12V WIRING FOR ANGLE-MOUNT DISTRIBUTOR:
